manifold studs
Like fish said, grind down busted stud level with the flange, then your drilling a hole through a shorter length of the broken stud, maybe a half inch tops. I center punch what I'm drilling since that makes it quick for the drill to find dead center. You use a drill bit just under the thread size of the stud to drill through the nub and then chase the threads with a tap to clean any remnants and face the flange threads to accept a new stud.
There are left hand twist drills for this too because many times just the friction and friction induced heat of the the spinning bit will begin to turn the broken bolt or stud your removing. If you can get enough exposed for long nose vise grips you can do that to turn it the rest of the way out.
If the drill doesn't turn the remnant or you can't drill dead center then you drill sized hole for a sized E-Z Out (I have five different sizes) which is hardened tool steel, left hand twist and use that to grab and turn the nub out.
With exhaust manifolds especially either super cool (Tom) or heat the flange to shrink the stud or swell the manifold just enough to turn the nub out with whichever method you'd like.
Sometimes just striking the flush ground stud with a center punch off center and at an angle can drive the nub around and out.
All are different methods to produce the same result.
? I had the Y pipe off. Usually the studs will shear off and be left in the manifold. The Y pipe doesn't have threaded holes so as long as you can get the nut off the Y pipe should drop. I drilled the sheared off stud with the manifold still on the truck. I really wanted to pull the manifold and drill it on a bench, but I was too afraid I'd shear off bolts going into the head.
....the easiest way to get er done, been there. Same for removing the exhaust manifold from the head, came out like buddah.
clint70 (07-24-2015)
Greg Duncan
08-17-2009 03:26 PM
raid13
05-13-2007 12:13 PM
