-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   My keyless entry Fob suddenly stopped working= (https://landroverforums.com/forum/discovery-i-39/my-keyless-entry-fob-suddenly-stopped-working%3D-44806/)
Doc Stone Oct 30, 2011 04:51 PM
any help would be appreciated
thanks
Doc Stone
adigerol77 Oct 30, 2011 05:02 PM
Doc, possibly the batt in the fob? Did you change anything lately that would cause a reset?
jafir Oct 30, 2011 06:29 PM
also, what year is your disco? You might want to make it part of your signature, as it will help the community help you.
Doc Stone Oct 30, 2011 11:57 PM
1 Attachment(s)
Attachment 44314
My Land Rover is a '96 model=
I did change out the battery after the keyless
entry stopped working=
I tried pushing the door locl button 4 times
as discribed in the owner's manual=
didn't work=
light is coming on when buttons are pushed=
I'm a newby LR owner so=????
thanks much
Doc Stone
jafir Oct 31, 2011 12:22 AM
You've done everything I can think of. Does it not lock or unlock either?
Too bad the 96+ requires a computer to tell the car to learn the remotes.... because the next step might be resync the remote, or replace it and resync it.
Doc Stone Oct 31, 2011 06:07 AM
No,
it will not open, lock or
start the car=
guess I'll just have to use the keys=
thanks for the interest=
Doc Stone
jafir Oct 31, 2011 07:37 AM
start the car? that's not a feature available on a 1996 land rover. It sounds like you have an aftermarket alarm system installed. You might need to check with the manufacturer of the alarm, they may have some steps for pairing the remote with the system.
fishEH Oct 31, 2011 08:42 AM
On a OEM FOB: Pop open the remote. Remove the battery. There are three solder connections on the metal clip that retains the battery. Those connections tend to come loose and need resoldering. It sounds like you might have an aftermarket remote though so IDK. Post a pic of it.
Doc Stone Oct 31, 2011 08:49 AM
I will post a pic when I get home tonite=
yes, it would remotely start the car, when
working=
thanks=
Doc
Disco Mike Oct 31, 2011 09:01 AM
There is the problem, it is an aftermarket remote which usually cause problems at some point.
