Need Help with 96 Disco, Will only go while Diff is in lock
Old 01-21-2011, 09:17 PM
96LRD1's Avatar
Default Need Help with 96 Disco, Will only go while Diff is in lock
I bought a 96 Land Rover Discovery1, Kalahari Edition and was told that it was stuck in Diff Lock. However it seems to engage in high and low diff lock fine as well fully goes in H and L diff unlock. And I am lost because while it is unlocked and fully engaged it will not go anywhere. It seems to be in neautral, Park will not even work? When I lock in the diff H or L it runs great. Can somwone please help me in this matter. Thanks
Old 01-21-2011, 09:26 PM
tweakrover's Avatar
There is something in the drive line broken, or someone removed a driveshaft for some reason. When its unlocked all the power is going to the free spinning end.
Old 01-21-2011, 09:46 PM
pedronz's Avatar
Default no drive
check you have 2 drive shafts. if so, put it in "no difflock" positon, chock wheels first, climb under the vehicle and turn each drive shaft, rear then front, the one that turns indicates the bit that is broken, front or back, then pull the end apart to inspect, you may need a small bar to turn it.
cheers
Old 01-21-2011, 09:47 PM
lordmorpheus's Avatar
X3. Both drive shafts installed?
Old 01-21-2011, 10:49 PM
Spencerfitch's Avatar
most common cause is broken cv joint up front or axle.
Agian check for TWO drive shafts.
Old 01-22-2011, 05:35 AM
low on blinker fluid?....
like everyone else said. check to make sure there are two driveshafts if there are you need to hunt for the exploded u joint
Old 01-22-2011, 10:44 AM
96LRD1's Avatar
Yes Both drive lines are installed
Old 01-22-2011, 10:46 AM
96LRD1's Avatar
So to my understanding the driveshaft that turns freely, i will need to replace the u joint
Old 01-22-2011, 10:52 AM
96LRD1's Avatar
I was told when I bought my disco it need a swivel joint and also the part came with this, could replacing this solve the problem? I have been tole so many things, this is the reason I joined this formu bc everything I seen that made sence came from all of you. So I am going down to today and doing all of the above and let you all know what I have found and I hope we can go from there, Thanks to all of you who responded. I hope to get this one repair done so that I can drive it, I was told I would ruin it if I drove it, is this true as well?
Old 01-22-2011, 10:55 AM
OK, so both drive shafts are installed, correct? What have you checked/tested so far, and how did you do it? The testing method is very important, as an improper test can lead to an incorrect diagnosis, and unnecessary part replacement.
Quick Reply: Need Help with 96 Disco, Will only go while Diff is in lock
