No Wading
You might be driving along fine in water 2' deep and suddenly find yourself in water 20' deep.
There's a reason you're supposed to check water depth on foot before wading.
I was half joking about being upset about it.
http://www.670kboi.com/rssItem.asp?f...temid=29644123
next block over from my house.
It's because when a road is flooded there's no way for a person to tell if a culvert, bridge or road is washed out.
for this reason i thought about some type of tool you could attach to the front of the truck with a wheel on it and a long pole inside a larger pole that would mount to the bumper. and as you drive along if the wheel dips drasitcally you will see the top of the pole slide down and know to not go any further because the road has gone out. only problem is, unless you live in a flood prone area how often would someone use it and secondly you would have to have some sort of angle on it so the wheel could lead the truck by a few feet.
