-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Odd CLD shifter issue (https://landroverforums.com/forum/discovery-i-39/odd-cld-shifter-issue-57825/)
Randall in NC Mar 23, 2013 09:24 PM
I purchased a '98 Disco just a couple of weeks ago with high miles but the PO said that the engine and tranny was rebuilt and has about 90k on them. I drove the truck 2.5 hours home to discover a weak alternator and leaking water pump. I replaced the alternator, water pump, t-stat, and all of the hoses. Today I tightened up the gearbox, changed the oil, and drained and refilled the transmission fluid. After refilling the transmission, the truck would not shift into gear. So I added fluid until the truck would shift, now appears overfilled. I then began moving the cld shifter and noticed that the truck was in low when the shifter was in high and in high when the shifter was in low. Is this a linkage issue that someone else has experienced? I wish to drive the truck but would like to make sure I do not damage the transmission. Thanks in advance...
Spike555 Mar 23, 2013 10:34 PM
Sounds like a linkage issue, like it was hooked up wrong.
As long as the CDL is not locked you can drive it, if it is locked you cannot drive it on dry roads.
The transmission and transfer case are two different units, the t-case takes gear oil and the trans takes Dexron III.
Randall in NC Mar 24, 2013 12:20 PM
I adjusted the kickdown cable today (too much slack) and drove the Disco about 20 miles in Low (per the CLD knob position) and the truck drove/shifted great. I moved the knob into the High position and the transfer case is defiantly in Low, in CLD locked and unlocked positions. I will take a look at the linkage this week, raining here in NC at the moment. Ordering a new Brake master cylinder for this weeks Disco project as well:) Thanks for your help...
Scope Mar 24, 2013 01:11 PM
Yup,raining here too and kinda cool for spring.Maybe next weekend.
Spike555 Mar 24, 2013 04:27 PM
Make sure you buy a OEM master cylinder and NOT a aftermarket brand.
