Oil Cooler Lines
Oil Cooler Lines
Hello, I've got a 97' D1 and I was wondering if anybody knew how many oil cooler lines there are and the best place to buy them online for the buck. I have a leak coming from somewhere, and I thought i would changed out the lines, and see if that fixed it. The other part I'm looking at replacing is the steering box. Any help would be great, thanks.
www.roverlandparts.com
www.atlanticbritish.com
www.roversnorth.com
www.google.com
www.ebay.com
The most common leak on a DI is the valve covers, a 8mm 12 point socket will fix this.
The second most common is the oil psi sending unit, it is right above the oil filter and can be had at your local autoparts store.
www.roversnorth.com
www.google.com
www.ebay.com
When i was under the Disco this morning, i was trying to figure out how many different oil coolers lines there are, so far I see a least 3-4, two which go back towards the transmission, and one that makes a loop around from the top to bottom portion of the driver side radiator. Any others that I might be missing?
I also had leaks coming from the transmission cooler lines, and had them replaced. You may also have leaks there, but you may need to wash the underside to be sure.
Cool, thanks for the help guys, I found a nice layout on www.roversnorth.com, there are three lines that are leaking on mine, the two transmission lines and the cooler to cooler line on the right side of the radiator.
