And the other shoe falls off...
g'morning... i get truck running and now i can't put it into gear... LOL... anyway gonna check to see if there is a brake switch/wire that is faulty not allowing the automatic gear shift to move... any advise?
on a side note... is it pretty simple to replace stereo in a 97 Disco? |
Buy the install kit for your new radio, the plastic fascia on the old Discos is super brittle and wont support much. There is a aluminum shelf that the factory radio sets on, but it is screwed to the plastic fascia. You will need a 2.5mm allen to remove the factory radio. Good luck
Originally Posted by RobertBrowning
(Post 314852)
1 Attachment(s)
May also just be a fuse - see attached pages from RAVE, BTW it would help if you include your truck year and miles in the signature.
checked breakers... no love... going 2 follow path as per provided diagram (thx again - as usual Savannah Buzz)...
Check to see if you have brake lights
good call, priceg... tested all lights last night and they were good... no lights now... do you think a disco can be allergic to a Full Tank of Super Unleaded? :}
The brake light switch on the pedal supplies an input for the shift interlock solenoid. Part of the self adjuster fails so it does'nt lock into place. I have glued them in a pinch situation.
will try it, priceg... is there a proper way 2 fix it?
No, replacement is the only option. You can remove it from its holder with it plugged up and manipulate it with your finger to get the trans out of park, however your brake lights will still be inop.
| All times are GMT -5. The time now is 12:12 AM. |
