-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   P1448 error code? (https://landroverforums.com/forum/discovery-i-39/p1448-error-code-37235/)
pimnmike Jan 10, 2011 11:22 AM
P1448 error code?
Hey guys yesterday my CEL came on and the code was P1448. My truck runs fine and sounds ok. What does the code mean? Gas cap, fuel lines, purge valve & canister which I can't find anywere. Is this something I can drive with or does it need to be fixed immediately?
Chris-bob Jan 10, 2011 11:54 AM
The P1448 fault indicates a leak in the evaps system. Check all of the vacum lines that go to and from the purge canister and valve. look for cracks and the like.
pimnmike Jan 10, 2011 12:29 PM
Where is the canister and valve?
Chris-bob Jan 10, 2011 12:54 PM
Generally, they are located on the pax side against the inner wheel well. Download the RAVE so you have access to the info you need, such as component location and troubleshooting tips.
Danny Lee 97 Disco Jan 11, 2011 12:49 PM
It looks like a black coffee can with two hoses attached to the top sitting on the passenger wheel well inside under the hood.
X2 on downloading and using the RAVE.
Disco Mike Jan 12, 2011 08:00 AM
The code, more specifically is the evap purge valve flow 2 fault.
pimnmike Jan 27, 2011 01:00 AM
Ok I downloaded the RAVE. So much information. I could read it over and over again. Now I checked my lines they look fine no cracks and everything hooked up nice and tight. Is there a certain way to clean the purge valve, my CEL is still on? The RAVE tells me how to take it off, but I couldn't find how to service it.
