Passneger side water leak 1995 Discovery I
Hello all,
The current issue is when it rains, water is slowly leaking into my passenger side footwell. I removed the seat and the carpet because the windshield was originally leaking on my divers side. I was able to get it resealed and took care of that leak. This past week I checked my sunroof drains. I don't believe its the problem, A) When I put the hose on the windshield only it leaks in. B) When on sunroof with towel stopping it from going down windshield it doesn't leak. I bought silicon caulking and caulked the area between the windshield (under the black trim piece) to the hood. I also caulked around the intake for the air vent (just because) I then sprayed it with liquid rubber. Its a product that is for undercoating. Does anyone have any suggestions where to look for the water leak? I thought maybe it was the heater core but its NOT coolant. It also leaks in on the right side of the dash by the door. Any thoughts are welcomed and appreciated, Thank you! |
condensate (water) drain for AC? Perhaps nipples under the tranny tunnel are plugged up.
Quote:
I'm thinking that the dash is going to need to come out... |
If you recall, I had a big rust thread a while back.
Theorizing here, but from what I could tell through dismantling, my floor rust was due to a leak halfway up the A-pillars, which are also rusted. In mine, it wasnt a roof thing. I have holes rusted in the area where the hood hinges are. To fix it up, it looks like fender removal is in the future. Thankfully, that doesnt look difficult. |
Quote:
Oh, I didnt mean to imply that yours was as bad, haha. Just letting you know of a possible leak source that isnt readily apparent.
Obviously not a disco, but this arrow points to the area I am talking about. http://www.wkjeeps.com/misc/Caliber/...er_leak_08.jpg |
Quote:
**UPDATE** Just went out and put water on the windshield and the water is actually draining off the windshield, over the black seal at the bottom, then down behind the black piece of plastic and straight into the air intake for the cabin. Now the question is, how do I fix that leak? I should add that I recently had a water leak on the drivers side that caused the windshield to be resealed. I didn't notice a water leak on the passenger side before this reseal. :eek: |
Oilspot- reach up into the pass footwell above the side plastic kick panel and feel the sheetmetal up there at the side of the bulkhead. I found on my drivers side when I did that I accidentally knocked all the crusty rust out and made it worse- so now latter in the summer- it's fenders off for me. I think ptschram posted a pic of a repair in that area in Pinky's rust post. Good luck.
Quote:
I have never wanted to get rid of this truck as much as I do right now. I just can't find the source of the issue! AHAHAHAHH Considering I could part it, then buy another for 2k is sounding really good right now! (RANT OVER) l:mad: |
Quote:
| All times are GMT -5. The time now is 03:10 AM. |
