| Rover_Hokie |
May 14, 2013 10:29 PM |
I tow a 23' travel trailer that weighs in at 4,000-4,200 lbs. loaded. It does OK, but you will definitely down shift up grades and be maxed out on your speed just trying to maintain 50-55 up the steeper grades. You will want to make sure your trailer brakes are working, and you have sway control. D2 brakes need to be in good shape as well. Fresh/clean tranny fluid, and cooling system in good order. Upgraded rear springs may be useful too. I went with upgraded OME MD springs all around and a wt distributing hitch, although LR says you are not to use wt distributing hitches. I have asked some LR people and no one seems to know why. It may be some difference in the towing setup from US vs Europe, not sure. I have been towing for 4 yrs now, and it works well. Anybody here know why or have a theory, I would be glad to hear what your thoughts are.
The length & height of the longer travel trailer compared to the short wheelbase of the D2 can make you feel like you are being pulled around sometimes, so take it easy with a 27' trailer. I would say it is a little too long, as I feel like I would not want mine to be any longer, but another 4" may or may not be that different. My 18' pontoon tows fine. I thought the pontoon would not feel like much behind the D2, but the 4.0 just needs a little more horsepower before that is going to happen, even with the pontoon. I borrowed a friends Jeep Grand Cherokee when my D2 was down one time, and did not even feel the pontoon back there with the 5.3L V8 engine under the hood of the Jeep.
Also, if you have not done much towing of more than utility trailers like me when I bought my travel trailer, the vehicle towing capacity specs are very misleading. What I have learned is that before you do anything you should leave a 10% safety margin. That takes you down to 5000# towing capacity. Then you have to subtract the weight of all occupants and gear/heavy upgrades in the vehicle, which was a surprise to me, but makes sense. The vehicle has to pull all that stuff along as well as the trailer, even if it is in the tow vehicle. I would of thought the specs would of at least figured in a 200# driver or something, (like the vehicle is going to tow without a driver). The weight the trailer places on the hitch ball has to be added in as well, and then the loaded trailer weight. So that 5,500 capacity is really much less when it comes figuring the weight of the trailer and contents that you can tow. My rough calculation towing my travel trailer with my D2 towing go something like this: 400-500# occupants + 500-600# steel rear bumper|sliders|roof rack|vehicle tools|gear + 3,500# empty trailer + 400# tools|gear in trailer + 350# trailer tongue weight resting on the tow hitch ball which puts me right at the 5,300-5,500# range. You need to review the other spec about Gross Combined Vehicle Weight (GCVW) which is the D2 factory curb weight, plus all the weight added in/on it, plus the trailer's tongue weight resting on the hitch ball which gives you the total of weight resting on the D2's axles. I cannot recall what that limit is.
Gas mileage is bad as well, not sure exactly but around 10 mpg or less.
