Radiator Removal
Radiator Removal
Hello forum. I am getting ready to remove my radiator and have it rodded out. I have the rave and am ready to do it. My question to all is. How long does it take to get it out? I looks fairly easy. I just need to plan so I can get it to the shop early in the morning. Thank guys.
see attached, about 20 minutes if I take my time. Be careful of small fittings for hoses #4, they are metal, but easily bent. Two mounting nuts and brackets off, pulls straight up. After all hoses an lines off, watch you don't loose O rings from the hard lines, will leak a little ATF and oil.
Buy new O-rings for the oil cooler lines, you will need four of them, 2 for the trans oil cooler and 2 for the engine oil cooler lines.
Oil Cooler Pipe "O" Ring (Part # ESR1594L) - Land Rover gaskets and seals from Atlantic British
Your local autoparts store will not have them, the radiator shop might though.
