-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Rear drivers side window stuck down? (https://landroverforums.com/forum/discovery-i-39/rear-drivers-side-window-stuck-down-62845/)
archaeology_student Oct 30, 2013 10:58 AM
Hi everyone,
I recently noticed my rear driver's side window stays down, and when I use the switch to raise it, nothing happens, other than some weird sounds.
What could have happened? Motor? Rail? Something loose?
dansgt Oct 30, 2013 02:19 PM
Regulator failed. Pull the door panel and likely your wheel broke off and the arm isn't in the track anymore. That's an easy fix, go to home depot or Lowes and get 1" nylon washers and use those. I ended up drilling out the rivets on mine and using the bolts and roller for a screen door.
archaeology_student Oct 30, 2013 09:33 PM
Thank you sir :)
Just happens to have started raining today, and no duct tape! Home Depot tomorrow ;)
