rear tail light covers
It depends on the style of the lamp guard.
If you have what's in the pic below those guards are # RTC9503AA and the hardware kit is #RTC9503K.
If that's what you have then give L8 a call any they should be able to get just the mounting kit.
I know it can be had > https://www.britishpartsofutah.com/D...p/rtc9503k.htm
BUT I would still call L8 first!
Here is the complete assembly/kit > https://lucky8llc.com/collections/di...ht-guards-pair
No doubt $82 is way spendy for B$!
Now that you have the mounting kit part number I would see if RN, AB, or Trevor @ RovahFarm would order it for you.
If not it's time to order from across The Pond. Search the part number there are UK options.
For example, Rimmer Bros lists the guards (not that you need those) and the mounts for $60 +S US. I'd bet they will have the kit too.
> https://rimmerbros.com/Item--i-RTC9503AABP
OK....NOW I have it figured out!
The RTC9503 (K) part number is BS from the BPU site that they "made up". Tricky bastard$
The Lamp Guard Kit Part number is correct at RTC9503AA
>>>> The Mounting Kit (LR calls it a fixing or repair kit) is STC8048 <<<<
Searching that number gives much more promising results.
RN looks like they can order it for $73.11(plus 10% off). > https://www.roversnorth.com/parts/st...it_rear_guards
Even the Online Dealer Sites in the US show this as a live number for less $. > https://parts.landroverhiltonhead.co...repair-stc8048
And again this part number is available at many shops in The UK.
That's all I got!
That's all I got!
