Originally Posted by whiskeynipple0088
(Post 667508)
not sure if you've tried but to resolver is really easy - you can unbolt the two nuts at the front of the ECU and swing the whole thing down (you have to remove one other bolt that holds a bracket below) for better access - and pop the front off and slide the board out - took me all of 15 minutes once I realized to release the 2 nuts
My 2 bits -- try the window without the card slid into the slot.. just connected and hanging in a SAFE - non metallic way. I had one case of a card that would work until it was slid all the way in. I assume there was another weak spot that I could not find and when slid in, it was putting pressure on the right spot to prevent it from working. I ended up leaving it about an inch out of the holder.
Thanks for the guidance! I ended up jumping around the ECU like its described in the Atlantic British instructions, however, I used my own wires and connectors. Thought paying $20 for that was a little unnecessary and I didn't want to wait on shipping. The job was very simple once figured out the problem.
Once I finished wiring it and gave it a try.... you all prolly already know what happened... rolled it down once and the little plastic circle son off a B broke... LOL! |
Originally Posted by jimvw57
(Post 668242)
https://www.youtube.com/watch?v=kt6odNB3c8s
right around the 6 min mark he shows the bad solder joint. |
| All times are GMT -5. The time now is 10:12 AM. |
