Rear windows
Rear windows
I have a problem. When I bought my Disco 1, both of my rear windows did not work. So I took them both apart, and tested the window motors, to a 12volt charge. They worked without hesitation. So, I put them back in. I checked my window switch on the center console, and it is still good. I just switched the plug from my front window, to my rear window to test. I also checked all of my fuses. The front windows work without a prpblem, its just the rears that I am having problems with. If anyone has a solution to this problem, please comment.
Thanks, gman21.
Thanks, gman21.
http://www.roverparts.com/Parts/AMR1282RK.cfm click on instructions on how to bypass/repair lift ECU for rear windows.
Why add a bypass on such an easy fix. If you have a solder gun around find someone with small hands to remove Ecu box and solder it 20 mins max. Window Ecu is under the passenger dash just find the bad solder joint and add some solder to make new contact. I have big hands and still just got a few little cuts.
6 of one, half dozen of the other really. I bypassed mine. I'm not sure what the window lift ECU even does to tell you the truth. I bypassed the ECU and the windows goup/down every time so I'm happy. Not sure what else I'd want them to do really. And its just one less thing to fail again in the future IMO.
Sand the old joint? Definitely didn't do that. Definitely DID leave a huge solder mountain at each of the broken connections, though. F-you, "less is more"! Hahahaha.
