-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   to rebuild or not to rebuild. (https://landroverforums.com/forum/discovery-i-39/rebuild-not-rebuild-54336/)
zukijames Nov 15, 2012 12:03 AM
so my gf has a 96 disco she cut up and made a buggy..
blah blah
well now we are converting to propane.
i'm thinking why we are in there might as well rebuild instead of put the new cover,intake ect. and then have to do head gaskets, and then end up needing a rebuild later
any opinions? or advice as far as rebuilding goes? best place to get parts?
are the liners big enough to have them bored out?
others wise wouldnt putting stock pistons back in a worn out liner = less compression?
Savannah Buzz Nov 15, 2012 08:25 AM
1 Attachment(s)
Don't believe you can bore out these liners. They are slip fitted, not cast in place. Parts from all the usual sources including Atlantic British, British Pacific, Rovers North, BP Utah, and a great many more. And there are intakes from the carb era, popular with the lads from the UK that squeeze the Rover engine into MGs and Triumphs. Lots of engine mods available. "RPi Engineering - Specialised Rover Engines" and The Wedge Shop - Fast. British. Reliable
You will have lots of interest on this site for the propane conversion, so posts lots of pix. I have worked with a lot of V8 standby generators in the past, and the ones run on bottle gas certainly had cleaner oil.
fishEH Nov 15, 2012 08:43 AM
Call Will Tillery and tell him you want his head gasket kit. He sells the bolts, gaskets, and a pair of machined heads with a valve job for around $600. Just have to send your old heads back. It's a good deal and a nice way to minimize down time.
zukijames Nov 15, 2012 08:51 AM
thanks for the info! can you get thinner liners? to run a bigger piston ?
Savannah Buzz Nov 15, 2012 08:52 AM
Or consider getting a whole engine from a wrecked one. You take a chance, but depends on GF's budget.
Savannah Buzz Nov 15, 2012 08:54 AM
See http://www.google.com/url?sa=t&rct=j...Hko5O2FrvYc-Ow - those liners look pretty thin to start with.
zukijames Nov 15, 2012 09:24 AM
dang they are way thin so there is no boring out to run bigger pistons? i need to do some homework.. im just thinking if shes going to rebuild it why not get a little more out of it.
EricTyrrell Nov 15, 2012 09:40 AM
The way to increase displacement on the RV8 is to increase stroke, by changing crank/pistons/rods as LR did when they moved from 4.0 to 4.6. Increase to 4.8 can be achieved by using 1964 - 67 Buick 300 crankshaft and '64 Buick 300 heads. Further increases to 5.2 can be achieved by custom crankshafts, connecting rods, and pistons. D&D fabrication is likely the best resource in the US for more info.
A standard rebuild isn't difficult. Just take it to a machine shop and tell them what you want done. Have them hot tank the block and heads, hone cylinders, re-ring pistons, valve job, check mating surfaces for flatness and resurface if necessary, replace seals, replace bearings.
Jake1996D1 Nov 15, 2012 10:06 AM
Buy a real engine!! The lt230 is the only thing worth keeping and buck has created an adapter to the nv4500...
ValveCoverGasket Nov 15, 2012 11:04 AM
why not buy a 4.6 and make that nice instead?
