-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Removing Theft Alarm System (https://landroverforums.com/forum/discovery-i-39/removing-theft-alarm-system-55685/)
gprtech Feb 14, 2013 07:44 AM
All of the Micro manufacturers have moved far beyond what was available when the 1997 Disco was built, including Atmel.
As far as info goes, nothing I will or have said will allow anyone to duplicate what I plan to do unless they've got a ton of equipment. time & expertise. Moreover, it applies to trucks built more than 10 years ago, and still requires you to unlock the doors & ignition with a key.
Also, the emulator would still require that you have the alarm, remote & key to generate the code for it to record.
It's not possible to steal a truck using the methods I'm talking about. It's to REPLACE the theft alarm, not eliminate it.
My more modern cars have no immobilization features of any kind. I like the starter disable, but that's plenty.
SSL9000J Feb 14, 2013 10:05 AM
:pIf someone steals my truck, they'd have to fix it.
gprtech Feb 14, 2013 10:12 AM
In a lot of cases, they'd have to fix the truck BEFORE they could steal it. :-)
96 rover Jul 16, 2013 09:41 AM
immobilizer bypass on 1998 with no spider behind radio
Where is the theft immobilizer on the 1998 disco. I have a 1995 disco and the spider is behind the radio. I have the shop man. and wiring diagram for the 1998 but cant make heads or tails of it. And has any one bypassed this with out rewiring.
I can get it started with a screw driver across the coil on the starter and it will try to start with the key but the red dash indicator comes on and then it stops trying to start please help before I strip the truck for parts.:)
96 rover Jul 18, 2013 08:28 AM
By pass the immobilizer
Take the two wires on the green box (one of the plugs) that are black and orange/red looking stripped tie them together make sure you leave enough wire there in case you have to reconnect for some reason. Tie both wires together and that will disable the immobilizer. I did this last night now my 98 disco starts with no issues and all cab lights and features work fin will post pics this weekend if needed. Any questions please respond.:)
SSL9000J Jul 18, 2013 08:40 AM
Could you be more specific? Where is this "green box" of which you speak?
gprtech Jul 18, 2013 09:15 AM
This depends on how the 1996 and later theft alarm is configured. There are a number of options, but basically the alarm can be configured to diable the starter (passive mode), disable the Engine Controller (active mode) or both. If the alarm is configured for active mode, you can't remove it.
The "green box" (the actual theft alarm) is behind the glove box, along side the ABS controller.
Savannah Buzz Jul 18, 2013 09:33 AM
Steal my truck - pleeeze!
EricTyrrell Jul 18, 2013 10:49 AM
You mean configure the ECM? If the ECM is still expecting the mobilize code to start the engine, how would configuring the alarm unit be of any use?
gprtech Jul 18, 2013 01:29 PM
No, configure the theft alarm. I'm not sure how the disabling occurs, tbut I do know that I used a Bearmach Hawkeye scanner to disable that feature on my 97 Disco.
