.....and I just added his contact info to my signature.....
Just installed the replacement alarm and engine ECU from Paul. NO CHANGE. There is no Check engine light and it engine only spins. NO FIRE
NOw have to rent a car, shop can't get it in till next Tuesday. :mad::mad::mad::mad: |
I've been contemplating messing with the alarm system here soon. My fob doesn't work, so I'd rather switch to a new alarm system with remote start.
Originally Posted by RedRovin'
(Post 560877)
I've been reading up on some of those threads. Let's just say inr super determined to find a solution. Lol.
(Post 561108)
Thanks in Advance. |
I'm dealing with this alarm mess on a 97 xd right now. I'll keep researching online and in the vehicle. If I come up with anything other than cramming a 302 in this thing I'll let you know.
Originally Posted by Coachgeo
(Post 561091)
This has been discussed. You might want to search it. if I recall/understand right, they say it is not possible due to a specific code that must be sent to engine ECU from alarm ECU. An aftermarket alarm wont have that code and/or not have ability to send it.
I agree that the BCU has to send an unlock/disarmed signal to the ECU. In most makes you can get the ECU reprogrammed for stand alone mode (no BCU) but for Discos I assume that is by done by one person in the world and he doesn't have Internet or a phone. |
1 Attachment(s)
I found this pic for reference.
I found this tip on the net, anyone try this
Find the BLUE / GREEN (-) wire located at the Factory Security Module: the FACTORY SECURITY Module is located under the PASSENGER hush panel far to the right. Requires (2) 7mm bolts removed to access.Connect one end of a piece of wire to the BLUE / GREEN (-) wire Connect the other end of the piece of wire to Ground - (chassis) This will Dis-Arm the Factory Alarm, until the wire is removed Im assuming attach to the alarm module side.....????? |
| All times are GMT -5. The time now is 04:31 AM. |
