Resurfaced my brush guard
My brush guard has been annoying me with rust starting to show through the plastic coating. The fading coating also needed attention so I took the guard off and started stripping. The plastic is very hard to come off in cooler temps so I used a heat gun and razors. The heat gun helped the plastic come off in large pieces. Once all the plastic was removed, I used a wire wheel to combat the rusted areas. I then cleaned everything up with tar & wax remover and shot it with duplicolor truck bed liner.
The rattle can bed liner works best using the same technique as painting for the first few coats. Once you feel you have it thick enough, go back over it a few times with short burst to really bring the texture out. The short burst really helps the texture come out of the can and on to the guard.
This was hiding under the plastic
Wire wheeled waiting for a scuff sanding
A few coats before the short burst technique
Poor camera doesn't really pick up the texture
