-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   running light failure (https://landroverforums.com/forum/discovery-i-39/running-light-failure-42191/)
Harris97 Jul 10, 2011 09:10 PM
I have an issue with my front running lights. The blinkers work but only my headlights are lit up on the front. I've checked fuses nothings wrong there any ideas?
adigerol77 Jul 10, 2011 09:50 PM
Do a search on the forum, there was something similar to this about 2 weeks or so ago. It's more than likely your turn/headlight column switch but there are other signs.
fishEH Jul 10, 2011 11:05 PM
No, that's normal for D1's. There are no amber running lights. Turn on your parking lamps and you'll get: city lights IN the headlamps, and red taillights. Turn on your headlights and you'll get city, headlamps, and taillights.
I think you can put Defender dual bulb sockets into the front blinkers for always on amber parking lights. I looked into it from Rovers North and it wasn't worth the $$$.
adigerol77 Jul 10, 2011 11:12 PM
There are no front "running lights" per se. On the side caps of the front bumper there are the turn lamps that also do light up as running lights but nothing in the front.
Harris97 Jul 11, 2011 05:15 PM
Turn lamps only light up as I turnthe signal on
