-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Running rich, P1176 code (https://landroverforums.com/forum/discovery-i-39/running-rich-p1176-code-57908/)
ESPN Mar 26, 2013 02:59 PM
As the title states, I noticed recently my discovery as been running a bit rich. Gas mileage has been down by 2-3 mpg according to the ultra gauge. Also, it has occasionally thrown the code P1176, which I understand to be the ecu is putting the max amount of fuel that it can into the engine. Recently, due to other reasons, I have been hunting down vaccum leaks, but have had no luck in finding any. Has anybody else had this issue and would be willing to help figue this out?
Thanks
CUpgt Mar 26, 2013 05:30 PM
I had this problem. Check the vac line from the fuel pressure regulator to the manifold. It took care of my 1176 as well as a purge valve code and o2 heater circuit code. Also try cleaning the MAF
ESPN Mar 27, 2013 08:03 AM
I just replaced that vac line for the fuel pressure regulator. It didn't help. For anybody who has an ultra gauge, what are the normal mass air flow g/s readings?
