So what did you do to your Disco today?
#3761
When was the last time you replace the brake fluid? I had a failure after coming down Pikes Peak, water gets sucked in and when it gets hot becomes steam and only the e-brake saved an accident. replaced the bleeds because they were rusted from the water condensing. Cheap fix if you were heating up the brakes.
#3762
#3764
#3766
Did some spring cleaning, changed the plugs and wires, cleaned the throttle body and air filter. Wish I had done them earlier the motor is much smoother with better throttle response. Before the exhaust had some unburnt gas smell as well, which is gone now. Hopefully gained a few more miles to the gallon.
#3767
Not Technicaly today but within the last 1500 miles....
Between 212-214 K Miles
Battery
Right side view mirror
Replaced door seals with DII seals
Several vacuum lines
Plugs
Wires
Belt
Front, Rear, T/C 80-140
Greased U-joints
Greased drive shafts
Oil & Filter
Air filter
Tie Rod ends
Steering dampener bushings
Sway Bar bushings
Front O2 sensors
Chevy Viscous Clutch
DII Mirror
Ignition switch tumblers
Exterior bulbs
Blower switch
A/C charge
Rear window rollers
Cargo door latch spring
Dash lights - wheat grain
Rear wiper switch
Wipers
Melted off hitch pin
Battery
Plugs
Wires
Belt
Greased U-joints
Oil & Filter
Air filter
Tie Rod ends
Sway Bar bushings
Front O2 sensors
DII Mirror
Exterior bulbs
Blower switch
A/C charge
Rear window rollers
Rear wiper switch
Wipers
#3769
