So what did you do to your Disco today?
Old 01-21-2018, 01:45 PM
hrhoward's Avatar
Originally Posted by aemnky606
Installed an iPad mount and 2 USB chargers.
The 12 volt cigarette lighter jack not good enough for ya? 😉
https://landroverforums.com/forum/di...b-12vdc-87806/
  #4122
Old 01-21-2018, 02:08 PM
ihscouts's Avatar
How are ya gonna light up that roach if the lighter aint there?
  #4123
Old 01-21-2018, 02:10 PM
hrhoward's Avatar
There are plenty of Lucas switches around. 😅
  #4124
Old 01-21-2018, 06:29 PM
aemnky606's Avatar
LOL. Yea it is fine. 😉 The top plug is pulled off of it for a switched plug. But I also needed an unswitched for the GPS receiver I use with the iPad.
  #4125
Old 01-29-2018, 09:10 PM
ROB99DISCOSD's Avatar
Put in a new master cylinder. I guess TRW is Lucas now? Or has been for awhile?
Anyways I used the whole 20 foot 3/16 ID hose from each wheel bleed nipple back to the master to bleed the system. Actually worked very well. Interesting method I hadn’t use before. Effective if you’re not set up to bench bleed the master.
  #4126
Old 01-29-2018, 09:13 PM
jafir's Avatar
Calipers on 1999 through 2002 discos said Lucas while 2003-2004 said TRW, so I’m guessing that’s about the time when it happened.
  #4127
Old 02-01-2018, 09:31 AM
fishEH's Avatar
So you run a hose all the way from your caliper bleed screw back into the MC? How is that batter than just bleeding into a container and just topping off the MC?
  #4128
Old 02-01-2018, 08:49 PM
Honestly, I don’t know the ancient Chinese secret behind it. Something about being able to pump the living crap outta the system to remove all the air and keep the master constantly filled at the same time. I tried the usual methods and just could not get my master to properly bleed. Some way, some how, man, it worked. It also really isn’t much more difficult than the regular way as far as effort or complications.
You already gotta put a hose on each bleed nipple so you’re equal there and if you properly secure the hose to the master it stays put. Only difference I could see in the process is MAYBE spilling a slight bit more fluid in the changing hose positions to each wheel. But that’s more me not clamping the hose tight enough once or twice. It only requires one person which is a plus and you can sit there and pump and watch the air in the line go by until it stops.
  #4129
Old 02-01-2018, 10:25 PM
jimvw57's Avatar
Last time I bled brakes, I used a hand vacuum pup and opened the bleeder sucked the fluid and air until I had about 1/2 container and refilled the MC, worked well and didn't need 2 miles of hose or clamps. Whatever works for you I guess.
  #4130
Old 02-11-2018, 09:04 AM
aemnky606's Avatar
Replaced steering gearbox, no more leaks.
Quick Reply: So what did you do to your Disco today?
