So what did you do to your Disco today?
5 Attachment(s)
We have a post like this on the Porsche forum that is fun to read and add to on a daily basis. I searched and didn't see anything on the Disco 1 side so I figured give it a shot and see if people contribute.
I'll start. Put in a new steering box. Most of it was easy. The rebuilt box had kind of buggered up threads on the input shaft so I had to put the u-joint on first and then install the steering shaft after the box was in the car. You may ask, how can you do that when the steering shaft/u-joint goes past in the input shaft when the steering box is installed? Glad you asked. I mounted the bottom left bolt that attaches the steering box to the frame then rotated the steering box until I could just slide the steering shaft in the u-joint mounted on the steering box. Easy peasy. Took about 2 hours because I had to monkey with the buggered up input shaft on the steering box. Some pics along the way. Here's the goodness from RockAuto. About $450 delivered. I get $100 or so back when I return the core. If you get a rebuilt one, check it over carefully. I didn't and found out my input shaft had buggered up splines. Made the job take about 20 min extra dinking around. I have to now remove the steering wheel to get it on straight because of this messed up install.:mad: Attachment 9229 Up on stands in the garage. No ramp under the driver side because I wanted the room to move the creeper under and the ramp got in the way. They are a double safety anyway and I left the jack under the car along with the jack stands on that side. Pointed it nose out so I could use daylight to help. Attachment 9233 This freaking bolt was stripped by either the PO's shop or from the factory. Had to use a nut splitter to get it off. Use a torque wrench people!:eek: Attachment 9227 You'll need either a 34mm socket or a 1-5/16 socket to get the pitman arm off the steering box. Really like the simple design of the lock washer. 130 ft/lbs when you put it back on remember. Attachment 9231 A good torque wrench makes everything go smoother. Pricey but well worth it. Bought this when I rebuilt the engine in my 928. It's a Snap-On Tech Angle 1/2" drive.:D Attachment 9232 |
Just a heads up. Advanceauto lists a reman box for the DI at $201+ a core charge of I forget how much.
I only have to top it off every few months, though it looks like it leaks constantly. For now I'm watching it, eventually I may bite the bullet and get one of these reman boxes. Today I did nothing but drive my Disco home from work (3rd shift). |
We have a thread like this too, in the 'Roaming with Friends' section.
Yes I saw that but this is Disco 1 specific "what did you do"
Originally Posted by jeff spahn
(Post 308444)
Nothing, the HG has a leak and she ran hot. So she's just parked till I get parts and time :(
I just drove mine to work and back with no issues at the break neck speed of 60mph while I streamed Saturdays CarTalk that I missed.
So I guess you could say that I enjoyed my truck, does that count? |
drove it with my fingers crossed my front end doesn't let go, as I'm currently in the process of painting my daily driver.
I replaced the front gille from when my wife took out a mailbox in the snow...:mad:
Replaced my rear seats that were ripped up with newer used rear seats that weren't ripped up! Does that count?!?!
