-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Source For Door Moisture Barrier (https://landroverforums.com/forum/discovery-i-39/source-door-moisture-barrier-37456/)
LeakyDisco Jan 18, 2011 11:50 AM
Hi,
After pulling my driver/passenger door panels off a couple times for various repairs, the brittle plastic moisture barriers are mostly shredded.
Has anyone managed to find a source for a similar material that would work to replace the original stuff?
Thanks!
- Chris
Cosmic88 Jan 18, 2011 01:53 PM
good old home depot...
painters plastic drop cloth (polyethelyene sheeting) ....go with the thick stuff at about 8 or 10 mil. It comes is large rolls for commercial applications of folded sheets for diy at hope jobs.
OR
try this out???? I have never used it in this application so I have no idea how well it would stick... http://www.homedepot.com/Paint-Drop-...atalogId=10053
losinov Jan 18, 2011 02:02 PM
I'm just going to go to home depot and walk around/ask someone to show me a material similar to the one the barrier is made out of. Then just cut to fit and transfer the little speaker cutout.
What do you guys think the black sealant is? At least in my car it is black RTV lookin stuff
LeakyDisco Jan 18, 2011 10:34 PM
OR
Thanks.
I'll go check out the local Pro Build and/or Home Depot this weekend and see if they have something that closely matches the thickness of the original.
LeakyDisco Jan 18, 2011 10:36 PM
It does appear to be an RTV adhesive.
Chris-bob Jan 19, 2011 01:47 PM
What about http://www.hobbytown.com/Shop/coveri...y-film-white-6 ?
LordReaper98D Mar 13, 2025 07:03 PM
it isn't. It is 3M Butyl Paste. Find in 5 oz tubes at Napa, and other fine auto parts stores. Black and green box black and green tube with customary red 3M branding. Now you know.
3M Black Super Weatherstrip and Gasket Adhesive, 08008, 5 fl oz, 1 Per Pack
LordReaper98D Mar 13, 2025 07:08 PM
PS, you can also order it in butyl strips kind of like strips of tack gum stuck to a large piece of waxed paper. Peel and stick, then stick vapor barrier to strips.
Icannap1 Mar 13, 2025 11:50 PM
Home Depot
Gibraltar Building Products
50 ft. Butyl Sealant Tape Roof Accessory in Gray
LordReaper98D Mar 14, 2025 07:47 PM
Originally Posted by Chris-bob (Post 220963)
what about what??? Your link takes us to nowhere. Sorry.
i did answer the tread question about the black stuff empirically though. See my replys.
