Speedo Issue
Speedo Issue
I know this is a no bainer, but I don't like buying parts w/out a second opinion/confirmation: My speedo started a couple weeks ago fluctuating +/- 1-2mph when holding a steady speed. Now it will hold a steady speed but pretty regularly the needle will drop 5-10mph and immediatly shoot right back up.
VSS???
P.S. I checked all the easy to get at wiring/connections for tightness/corrosion first. To replace the vss, does the parking brake drum have to come off??
VSS???
MY truck did the same thing, I replaced the vss and all was well after that. Unplug the wire harness on it, one allen head bolt holds it in the case.....with the right combination of ratchet-extension-allen head socket---it will come right out (or at least it SHOULD). A fairly easy job,( and NO you dont have to operate on the brake drum) the hardest part is parting with the $175.00 for a handfull of plastic gadgetry and figuring out the right combination of tools. Good luck
