SRS light on
My battery was dead so I replaced it with a new one now the SRS light is on and won’t turn off. I check all the fuses and there all good. And info would be grate thanks.
When your battery drains below a certain voltage it triggers the SRS light. The system must read the power as insufficient to detonate the air bags in the event of an impact. Unfortunately, you will need to have the SRS light reset by someone with Testbook or similar diag computer.
thanks for the info I fixed it.I disconnected the battery overnight for 8 hours or so and when i reconnected it the light turnd off.
