-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Summer Engine Temps (https://landroverforums.com/forum/discovery-i-39/summer-engine-temps-126298/)
Yossarian Jul 14, 2025 04:58 AM
Summer Engine Temps
What engine temperatures are you all running in the summer months? When ambient temp is 90s with 100% humidity my 1998 4 liter V8 runs about 195-205F (90-96C). If I hit 205 I turn off the a/c to bring the engine temp back down. I’m trying to figure out what’s normal for a D1 4.0 so I can calibrate whether my cooling system is healthy or needs some deeper preventative maintenance.
WaltNYC Jul 14, 2025 07:28 AM
Your temps are totally normal. Recall the stock t-stat is 88 deg CELCIUS which is about 190 def F.
I use a severe duty fan clutch in the summer.. Hayden 2991. It roars like a garbage truck but helps keep things cool. Slow traffic is not a problem if I shift down to 1,2, or 3 and keep revs around 1,500 - 2,000. Full stop at traffic lights can be problematic.
94Disco1 Jul 14, 2025 01:10 PM
I also have the Hayden 2991 thanks to WaltNYC's suggestion from a few years back. I can also confirm it sounds like a garbage truck. But summer temps are down. I switch back to stock fan in the winter.
WaltNYC Jul 15, 2025 08:16 AM
Another suggesting regarding fan clutches.... put a bit of anti-seize on the water pump threads prior to installing the fan. When you change it back to a 'standard duty' clutch in the autumn, a simple tap on the wrench will have it spinning off in seconds. Otherwise they tend to corrode onto the water pump threads and are an unnecessary pain in the ass.
Harvlr Jul 15, 2025 12:09 PM
I completely agree with anti-seize on the fan to water pump threads.
stillruns Jul 19, 2025 07:36 PM
These do sound like a garbage truck. Funny, I have people stare at the front end when I fun up to the store and leave it running.
