TF relocation cones install questions???
Old Mar 2, 2013 | 02:28 AM
Walko327's Avatar
Default TF relocation cones install questions???
ok, so I just got some rear dislocation cones from terrafrima. they did not come with any instructions. can I get some input from those with these cones.
from what it looks like the round disk should mount on top of the rear coil spring seat, then of course the cone inside the spring and then secured via the bolt to the afformentioned plate? is this correct? I cant see any other way these would mount up.
thanks iin advance
Old Mar 2, 2013 | 08:21 AM
fishEH's Avatar
Give a link or a picture of the cones you have. Some cones mount on the top, some mount on the bottom.
Old Mar 2, 2013 | 08:48 PM
Walko327's Avatar
Terrafirma Spring Relocation Cones Rear-Pair (Part # TF510) - Land Rover miscellaneous from Atlantic British
AB website product page TF rear dislocation cones.
Purchased because at full articulation in the river bottoms the rear springs dislocate up top.
In the picture you can see the 6-7in disk that looks like it mounts to top of coil spring mount and then cone inside of spring bolted up.
Old Mar 4, 2013 | 12:05 AM
Walko327's Avatar
Bump.
Old Mar 4, 2013 | 12:12 AM
CUpgt's Avatar
Disk on top of spring perch, cone under like you thought
Old Mar 4, 2013 | 12:20 AM
Walko327's Avatar
AH-HA THANKS CUPGT. these and oil cooler lines and bumper/winch all starts @ 0700 ritght after work tonight. thanks for the quick bumped reply man.
Old Mar 4, 2013 | 07:22 AM
CUpgt's Avatar
No prob. I need to change an oil cooler line as well. The list never ends.
Old Mar 4, 2013 | 07:53 AM
fishEH's Avatar
No it doesn't. Here's my list to be done by May 1.
Old Mar 4, 2013 | 05:31 PM
CUpgt's Avatar
Don't bother with the D2 flares, just make a nice cut. Your list just reminded me of a few things I need to do too!
Old Mar 5, 2013 | 02:00 PM
Walko327's Avatar
Same here,need to fix crushed axle breather and extend both front and back.
Locked&Loaded
Feb 20, 2015 07:11 AM
TOM R
Oct 16, 2013 09:58 AM
NPB
Nov 29, 2012 09:44 AM
honda50r
Jul 30, 2012 09:39 PM
AuZZZie
Jun 24, 2011 04:19 PM
