Is there A
Old 07-26-2010, 06:25 PM
georgep's Avatar
Question Is there A
Cross reference list of parts that fit the D1 from other car types?
I know plugs and such but MAF and other parts might be the same under ANOTHER make and be cheaper. If I order a relay for the 1978 rolls it is $175.00. from Rolls but If I just use the part number and I bought the same relay for $65.00
Old 07-26-2010, 08:52 PM
The fan clutch from a 2000 Chevy Express with the 4.3 NO a/c fits.
The IACV from a Jeep 4.0 fits but may not work properly and the dealer will not program it for you.
Wheel bearings are standard Timken.
U-joints are $20...the most expensive part for the DI other than a engine or trans is the MAF, thats $1500 new.
Everything else can be had for cheap if you know where to look.
In other words, yes, you can Disco on a budget.
Old 07-26-2010, 10:08 PM
georgep's Avatar
Now that is gold plated correct! I thought the Testarossa was crazy at $1,200.00 for a sensor!!
Old 07-26-2010, 10:15 PM
georgep's Avatar
What is this then???
INTERCHANGE BOSCH 0 280 218 010
(0280218010)
ROVER MHK 100800
(MHK100800)
Application
Description Year KW HP CC LAND ROVER RANGE ROVER II(LP) 3.9 07.1994-03.2002 140 190 3947 LAND ROVER RANGE ROVER II(LP) 4.0 06.1998-03.2002 136 185 3950 LAND ROVER RANGE ROVER II(LP) 4.6 07.1994-03.2002 165 224 4553 LAND ROVER RANGE ROVER II(LP) 4.6 06.1998-03.2002 160 218 4554Our price : $79.95
http://www.deluxeautomall.com/land-r...10-p-3264.html
If this is true Mutley will get one ASAP
Old 07-26-2010, 10:18 PM
Arm and hammer's Avatar
I was under impression that the most expensive part is modulator - 2500$ new.Also it is good idea to make cross reference list in this forum.And for Testarossa sensor I would look at FIAT parts. By the way FIAT stands for Fix It Again Tony.
Old 07-27-2010, 06:44 AM
georgep's Avatar
Traded the 1988 Testarossa for a Motor home, that was the SMARTEST thing I ever did.
I had not heard the FIAT in MANY YEARS
Old 07-27-2010, 06:52 AM
antichrist's Avatar
(0280218010)
ROVER MHK 100800
(MHK100800)
Application
Well, what it isn't is a D1 MAF.
Old 07-27-2010, 12:23 PM
demonlarry's Avatar
didn't look like one to me, either, but, could it be a generic MAF sensor picture?
I didn't check the interchange...
on further inspection it appears the "years" are a bit out of whack too. 03.1994-07.2002??
Old 07-27-2010, 06:25 PM
Yeah their selling junk.
Here is their DI MAF.
http://www.deluxeautomall.com/index....525&year_id=42
Ain't no $80.
Old 07-28-2010, 07:21 AM
antichrist's Avatar
That won't fit his '85 Discovery. Considering the Discovery wasn't introduced until '89 and had twin carbs and that you can't legally import a non NAS Disco (which rules out everything to '94) who knows what MAF would fit. I suspect none.
Quick Reply: Is there A
