? For those with working a/c
Can you spin the clutch on the compressor while truck is off? My ac works when it wants to, I'm going to drain and refill system and see if that works.
Originally Posted by Sam95disco
(Post 558679)
if you are going to touch your system, it is not just drain and refill.
you must pull a vacuum between otherwise it is all for nothing. when you do pull a vacuum it should hold for 30-minutes @ 28 inches of vacuum, if not you have a leak. |
Originally Posted by drowssap
(Post 558732)
Ok, so I went to a local flea market to have ac checked. Guy checked the pressure and found out that the compressor is not gettin power to it. All fuses checked out ok. When the ac switch is turned on you can hear the engine rev up a little. When you turn it off the engine revs down. This also happens when ac is on and the max ac button( one with the snow flake icon) is pushed in.
Is there a relay for the ac? Could it be the ac control unit? |
1 Attachment(s)
Is there a relay for the ac? ...... |
Originally Posted by number9
(Post 563074)
Looks like K108 is the clutch relay. There's additional trouble shooting info in the Rave Discovery Electrical Troubleshooting Manual if a meter reader and have downloaded manual.
...... Had some spare relays, no go on that. I jumped the compressor straight from battery, it came right on. If I created a fused switch to the comp would that be ok? I know the system is regulated, other components make the comp go off and on with an ac system that has no issues right? |
I know the system is regulated, other components make the comp go off and on with an ac system that has no issues right? A thermostat is fitted in the airflow out of the evaporator to sense the temperature of the exterior fins. Should ice begin to form, due to a too cold condition, it will signal to disengage the electro-mechanical clutch on the compressor. Dual pressure switch This switch, located in the high pressure line between the receiver drier and the expansion valve, monitors refrigerant pressure and by means of the relay module controls the following system functions: 1. Refrigerant pressure drops below 2.0 bar, 29 lbf/in2 (due to possible leakage), the compressor’s electro-mechanical clutch is dis-engaged. When pressure rises above 2.0 bar, 29 lbf/in2 the compressor’s clutch is re-engaged. 2. Refrigerant pressure rises above 32 bar, 455 lbf/in2 (due to possible blockage), even with cooling fan operation, the compressor’s electro-mechanical clutch is dis-engaged. When the pressure drops below 26 bar, 375 lbf/in2 the compressor clutch is re-engaged. ...... |
(Post 563091)
Unsure what issues you may encounter by eliminating control by thermostat and pressure switch. System may freeze up or compressor could be overloaded.
Found the right relay, thanks for the help number.
