Turn signals and Hazard not working Removed Switch already (help!)
Land Rover Disco 1 - Turn Signal & Headlamp Switch Removal from the steering wheel area by watching a video. See pics. I do not know what to do from here. Everything looks clean but it says to clean things (not sure what that means). I was able to get the piece off without removing the steering wheel because if I just turned the wheel I was able to get the screw driving into the screw. What do I do form here. Please guys I am needing not too technical instructions. Thanks rover gurus!
Check out section H6. There is a fuse under the hood F4 30A and under the dash F1 15A. Both feed the hazard switch. If the hazard switch does not have power the blinkers will not work. Start there and work your way through the circuit.
https://www.dropbox.com/s/yg6e56ao1l...01996.pdf?dl=0
