Upstream O2 sensor replacement
I recently got a O2 sensor fault in bank 1 sensor 1. the truck was recently in a collision so I want to unplug it and reconnect before I replace it just to make sure its not a bad connection. ATM i cant tell if its mixing rich or lean, I thing since its just the one the mix is the same, but I cant find where its connected. the wire runs up over the bell housing it looks like and I cant seem to find it. Anyone done a replacement, or know about where the connecter is? its the driver side upstream sensor
thread on it https://landroverforums.com/forum/di...nectors-59342/
basically remove the 4 nuts holding the coils down and unplug them then remove from engine and that will give you room to access
archaeology_student
04-14-2013 01:51 AM
