V8 Thermostat Installation Direction?
As I view this image of the coolant flow for the V8i engine from the RAVE manual:
It's not crystal-clear exactly which side of the thermostat fits into the block. I've always heard SPRING-SIDE into the block, but after examining my WAHLER (German) thermostat, (and THE coolant flow direction EXITING the block at the housing that feeds the upper radiator hose) it sure seems like the SPRING-SIDE should be out for optimal operation of the thermo-valve. And the spring side DOES fit into the (top) radiator hose housing. Worse - the close up drawing in the same manual gives no better indication of this "polarity":
The Wahler thermostat in question: (Wahler #W0133-1636663 (88 C)
Any thermostat polarity insights specific to the V8i engine in this 1995 Discovery I ???? (SPRING: IN or OUT for the V8i?)
thanks!
Bob Peterson
Portola Valley, California
Algernon, 5-speed (now rare!) 1995 Discovery
thanks!
Bob Peterson
