Vacuum Line
b - 4....... BINGO!!!!!
That is the t piece for the vac lines for the Cruise Control (CC).
One line comes from the vac motor located under the Jack (if you still have one) just forward and underneath the air filter box. The T resides just forward of the Brake Servo. The second line runs to the throttle linkage where you should find a rubber diaphram conected to the linkage. The third line goes down under the brake servo and through the bulkhead to the brake pedal switch.
Download "Rave" in my signature below for the complete workshop manual with all that info in it. All that and more!
Also!!!!! change that brake fluid... it looks Black!
