-   Discovery I (https://landroverforums.com/forum/discovery-i-39/)
-   -   Valve stem oil seals (https://landroverforums.com/forum/discovery-i-39/valve-stem-oil-seals-64143/)
abran Jan 2, 2014 07:27 PM
I'm about to drop 2 sets of heads of at the shop. Anybody have any suggestions for a specific brand and source for valve stem oil seals?
The shop is more than familiar with disco heads, so I'm not worried about specs. I planned to have the heads cleaned, pressure tested, surface decked, valve seats re ground, and new valve stem oil seals installed.
Am I missing something?
Thanks
DiscoJag Jan 3, 2014 08:34 AM
When I had my heads done they shimmed a couple of valve springs. I guess they checked them for tension or pressure. The sticky valve I had was on one of the cylinders that had a weak valve spring. It will run like a new truck after the head work.
abran Jan 3, 2014 11:09 AM
Thanks!
Thanks Jim, I can't wait!
