Vibrating brake pedal?
It was icy out this morning and whenever I came to a stop while driving, the brake pedal would start vibrating and making a clicking noise. Not at first, but right before I came to a full stop. Im thinking it might be abs. The abs light comes on when I first start it up, but it turns off when I start driving.
Any suggestions? |
That would be the ABS keeping you from sliding by modulating the brakes. As far as coming on when you start up, if that is beyond the normal 3 seconds Power On Self Test (POST) that most of the warning light do, it deserves more investigation. You can take out the ABS fuse in the underhood box for diagnosis, some don't like it and drive with it disabled.
So it is normal for the abs to make that noise and have the pedal vibrate? My parent's car has abs and it doesn't do that when it is working.
As far as the light goes, it seems normal like you said. |
All ABS vehicles do pretty much the same thing, is this your first vehicle?
Do not worry cause it is doing it's job. |
Yes it is.
Originally Posted by ESPN
(Post 279207)
Yes it is.
Originally Posted by calebbo
(Post 279208)
Nice! :)
I love the red, which is my favorite color by the way, I thought of getting mine painted later down the road but I probably need to wait, she had just gotten fresh black laid on her when I first got her.
Great 1st. vehicle.
Have you started doing any of the services probably need, such as all the fluids and a tune up? Need any help with this? |
Originally Posted by Disco Mike
(Post 279218)
Great 1st. vehicle.
Have you started doing any of the services probably need, such as all the fluids and a tune up? Need any help with this? Things I've done so far... New brake pads New serpentine belt New fuel filter New fuel pump New spark plugs New muffler Cleaned throttle body Rotella 15w 40 oil New air filter Flushed brake fluid Fixed frozen CDL I plan to... Change t-case fluid Change diff fluids Coolant flush |
| All times are GMT -5. The time now is 08:10 AM. |
