What is this?
What is this?
My ultra guage threw a pending code at me this morning via alarm when driving to school. I checked to see what it is and it is and the code is P1179.
Looked up the code on a Land Rover trouble code website and it says the code is "Maximum Negative AMFR Correction Fault."
What in the world is this and what is wrong?
Btw, the ultra guage is now my land rover's best friend.
This codes relates to ECM activity in terms of correcting a rich or lean fuel mixture. Your particular code is: Maximum Positive Air Mass Flow Rate (AMFR) correction fault. P1179 is the other end of the scale is Maximum Negative AMFR correction fault. It would seem you would have to investigate the reason your fuel mixture is beyond the correction abilities of your ECM. First, make sure you have a clean air filter and replace it if it is time to do so. Next, check for leaking or cracked intake manifold hoses and check for intake manifold leaks by spraying starter fluid around the base of the intake manifold with the engine idling. Finally, check connections to the Mass Air Flow sensor and clean the MAF sensor wire with CRC sensor spray. Beyond these simple steps, the next steps would require removal and cleaning of the throttle body, but in most cases the steps outlined cure the problem. Good luck!
on
Leave your MAF alone and look towards the 02's, how many miles on your engine and have you changed all 4 02's yet?
Read this link.
Land-Rover P1179 OBD/DLC Error Code -
Read this link.
Read this link.
Read this link.
Using your Ultra-Gauge watch the O2 readings, specifically the fronts, watch the voltage changes, they should be frequent and big changes, like from .95v to .20v then .45v etc.
Those are not the numbers you need, just giving you examples of what to look for.
Also watch your MAF readings and it is recommended to clean your MAF once a year.
Also, what is the name of the gauge that I need to set up? I don't remember seeing one while scrolling through the list that said "02 sensor voltage" or something like that.
