Whining, ticking and dripping
Ok, I have been rolling through Disco Mike’s list and fixing or replacing worn out or fuggered “fixes” from the previous owner and I am to this point:
https://cimg0.ibsrv.net/gimg/landrov...8950df0df.jpeg My desert prize https://cimg9.ibsrv.net/gimg/landrov...40562d838.jpeg Valve cover gasket leak |
Well my 30 second video must be too big. :dunno: |
https://cimg2.ibsrv.net/gimg/landrov...2df5713dc.jpeg dripping on the cat https://cimg1.ibsrv.net/gimg/landrov...ac9e5187c.jpeg Missing exhaust manifold bolt I kinda wonder if someone did a half assed HG job and just didn’t do a very good job? |
I'd guess the bolt on the exhaust manifold broke and is still in the block and am surprised you don't have an exhaust leak. In fact, an exhaust leak is what you my be hearing as a 'tick'.
Regarding coolant at the base of the valve covers... does anyone else think that is an odd place to find coolant? |
Regarding coolant at the base of the valve covers... does anyone else think that is an odd place to find coolant? I would be looking at the Throttle Body Heater Plate Gasket and the hoses going to it. And IMHO, those Home Depot hose clamps are garbage. Also check the TBH Plate itself, it's very easy to get a small crack or even loosen the nipples when removing the old hoses. |
I will definitely look at the Throttle Body Heater Plate Gasket and the hoses going to it. Do you have to take the whole throttle body off to access that?
For the exhaust manifold bolt, I haven't probed the hole yet but I agree that it probably has a piece of the old one lodged in there. The ticking though sounds like it is coming from the other side of the engine (under the passenger side valve cover) i.e. lifter, rod or rocker, perhaps. I have a video on my phone that really gives the listener clear sound of both the ticking and the whine in the front of the engine which started just before xmas. Is there a special way to download video here that I am missing? |
Originally Posted by NVRover
(Post 678482)
In the "user cp" section there is a section called "Pictures & albums" where you can upload photos and maybe video to link into the forum. It is a bit cumbersome but it works pretty well. |
You guys were right. I have a leak at the hose connecting to the TB heater. I think the heater hose may be to large inside diameter, so I’ll get some new hose tomorrow. I hope that takes care of the leak without pulling the TB off. Now on the exhaust manifold...I probed the missing bolt hole and it appears that it may just be really dirty but clear of broken bolt bits. I need to clean and chase the threads. I checked the rest of the EM bolts and all but two were loose and one was finger tight. So it’s not out of the realm of possibility that the missing one just fell out and PO just never noticed. I think new gaskets and bolts may be appropriate. |
Ok, throttle body off and yep, the heater gasket had issues. I have a replacement Britpart gasket but it has an extra nubin on it that doesn’t look like it should be there. Is this a bad gasket or am I missing something? https://cimg0.ibsrv.net/gimg/landrov...a3118aec5.jpeg https://cimg2.ibsrv.net/gimg/landrov...b1985ed1b.jpeg https://cimg3.ibsrv.net/gimg/landrov...e48296a61.jpeg |
