World’s easiest PCV
World’s easiest PCV
Unlike my D2 that came with a plastic Christmas tree that got stuck in the valve cover, which needed the top plenum and valve cover off to remove, the ‘97 D1 that I am driving now came with just two simple hoses, one from each valve cover connecting to the plenum. A quick removal, spray with CRC throttle body cleaner, and clean the orifices if dirty, and re-install. This little piece of preventive maintenance is very easy to do, and it doesn’t hurt to check every 6 months or so. Once the hoses are hard to squeeze, one could simply replace them.
Not sure, but I think there may be benefits in having a pcv on each side of the engine, instead of just one?
