01 dicso II instructions to change head gasket..please
01 head gasket..please help failed again
I am going to attempt to do the head gasket on my 01disco II. Just posted the headgasket thread, (found lots of useful advice on the site in other related threads...everything but the process of how) temps are going up to 34 this weekend..so I won't freeze in the unheated garage
Does anyone have the technical doc that describes this process..step by step?
I know the general process label all elec plugs I disconnect, drain rad, remove intake, remove exhaust manifods, remove heads..etc. But I am sure there is a very detailed outline of this process somewhere.
Please email it to iprocureit@yahoo.com, or just point me to the link. This looks like a 12hr job by a pro...looks like 36 hours for me. Also where do I get parts..local dealer or somewhere on line...cheaper? I know I need new head bolts as well.
Thanks,
Phil
Thanks,
Phil
Last edited by bigfun; 04-01-2009 at 08:36 PM. Reason: problem again with head gasket...HELP
on
RE: 01 dicso II instructions to change head gasket..please
Well the good news it is a 5 hour or less job for a pro.
Make sure to use only Rover gasket kits and new head bolts. While doing this replace your plug wires with a new set of 8 mm Magnacor wires, new t/stat, new upper radiator hose, if you have the olf style.
Also do an ATF flush before starting, will make it alot cleaner to work on.
Read the manual..
Get an understanding of what is what..
Then disasemble it.. use a cart or tray to place your parts on, labeling them if you need to..
You are going to need to get new head bolts to put it back together....
I think Ive read that before.. dont reuse the old head bolts.
COOLANT IN OIL AGAIN>..just replaced head gaskets?
Ok really getting frustrated. After successfully completing the head and intake gasket exchange on my 02 discovery just 4 weeks and $800 ago(gaskets, plugs, wires, belt, bolts) dealer ripped me for parts I provided the labor.
I HAVE COOLANT IN THE OIL AGAIN after it ran perfect for the last 3 weeks.
I had zero problems for the last four weeks, no leaks no sensor idiot lights. This morning when I started it the SRS, and Incline idiot lights were on? I looked under the hood for a loose wire or something that could have melted...nothing. I checked the oil (have been every week since I finished the job) and this morning it was up 1 qt, and the coolant was down 1 qt. COOLANT IN OIL AGAIN.
What else could it be? Did I mis-diagnos the Head Gasket? It didn't lead until now..4 weeks after I completed the job.
PLEASE help, not looking forward to another teardown...where else would it be leaking?
There were no obvious cracks that I saw in the heads, block or Intake when it was apart?
thanks,
Phil
thanks,
Phil
