-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   01 Disco - how much fror a new Key (https://landroverforums.com/forum/discovery-ii-18/01-disco-how-much-fror-new-key-38272/)
msm15 Feb 13, 2011 07:14 PM
01 Disco SE, only 1 key, how much does it cost for a new key, does it have a chip in it, does it have to be programmed by the dealer ?
Thanks
Spike555 Feb 13, 2011 08:38 PM
http://www.roverparts.com/Parts/CWE100710KITG.cfm
The remote needs to be programmed by the dealer.
If all you want is the key you can have a copy of yours made.
http://mysecuritypro.com/landrover.aspx
Just find the key blank number and then take that to the hardware store and have a copy made.
You will need to remove your key from the remote.
msm15 Feb 14, 2011 07:23 AM
thanks, I have a key cutter at work, these dont look like difficult keys to cut, I am wondering if I can cut them myself
dcarr1971 Feb 14, 2011 10:32 AM
Yes...as long as you know what you're doing, you should be able to do this yourself if you have the right equipment. My experience has been that most hardware stores had problems doing a decent job with my Rover keys, but I found a locksmith and he produced 3 copies (he supplied the blanks) for less than $6 total.
msm15 Feb 14, 2011 10:33 AM
wow that great
