03 front bumper fitted to 02?
the discovery i just bought has a broken front bumper, its an 02.......i plan on changing the headlights anyways.......can an 03 front bumper with fogs be fitted to the front, i would assume it could as the body and frame are the exact same minus the headlight unit, trim under the headlight, and bumper assembly
thanks! |
So, do your home work, you will learn more by researching the hundreds of post on all the Rover forums, and yes it can be done.
| All times are GMT -5. The time now is 08:59 AM. |
