04 CDL Shifter in 00 Dii
So I attempted to install the 04 shifter today. Unfortunately I'm not able to unlock CDL with the shifter. The lever does not move far enough to turn the cdl bolt far enough. If I pull the connector on the cable, then I'm able to move the bolt that little extra bit that is needed to unlock, but the lever doesn't move any further. Any thoughts on how I may be able to adjust/modify this shifter to work properly?
Before you bolted in the '04 transfer case lever, did you enlarge the opening on the plate that it mounts to? I used a dremel tool to notch the plate on my '00 before I bolted it in. Had I not done this, the lever wouldn't have enough travel when moved to the left.
..Or is it a problem with the steel cables bound within the sleeve? |
Originally Posted by lordmorpheus
(Post 485535)
the 04 locking solinoid has been removed from the shifter?
Originally Posted by drowssap
(Post 485564)
Did you try adjusting the cable? There is a adjustment where it attached to the bracket by the nipple. The cable is threaded with a nut on each side of the bracket.
Originally Posted by acamato
(Post 485652)
