04 Disco won't start
OK, I'm brand new to this forum, so be gentle. I have had sooo many problems with this truck, but my mechanic finally has it purring, but the alarm system will lock it up every so often and at random. I decided I just wouldn't lock the doors and for weeks now it's been great, but a few days ago I came home in a pouring down rain and got something out of the back door and didn't notice that I didn't get the door completely shut in the storm. The next morning It wouldn't start again, so I just took my other car to work. I found the hatch open when I got home. I first thought I had drained the battery, but all the dash lights and sounds are OK and the headlights, radio, and air all work. I put a jumper on it and it read the battery at 12.5 volts. I found the key code and tried it several times....nothing....there is a zero in the code, I thought maybe I wasn't doing it right?????? I'm ashamed to call my mechanic again, because that last time I took it over it had started as I had called for a tow and they never could get it to lock up......HELP.....I'm just an old lady wanting to drive her Disco!
I bought a DII three months ago and literally the first thing I did after taking possession of the car was removing the fuse for the door locks. I then drove it directly to a independent Land Rover shop and paid them $100 to disable super lock and the anti-theft system.
I then plugged the power lock fuse back in.
jamest47 (07-03-2018)
The works to the remote were stolen when I bought the truck, so I use the key for everything. The truck's starting system locks up, not the doors, but I think you are right on about the alarm system being disabled.....do you think my mechanic can do that? I have to drive 150 miles to the nearest LR dealer, but if that meant my truck would start, I would do it. Do you have any idea how I could get it to start now, perhaps disconnecting the battery? I really appreciate your taking the time to answer this as everyone in my family and friends are trying to get me to get rid of my D II, and I really love driving it. Thanks sooo much!
Does it make any sound, when you turn the key to the crank position? Could be something as simple as bad cable connections; at battery, starter or ground cable to engine. Starter could be bad also. Rule out the simple stuff first, before going crazy looking for something that isn't there (like super lock or security ststem).
Have somebody slide underneath and jump the two terminals on the starter and see if it cranks.
Brian.
Brian.
This truck has been in the shop too many times to mention, and everything has been checked and rechecked except the alrm system. Until the other night was the longest it had been driven since I bought it (2 yrs in Oct) and that was because I didn't lock it all that time. Oh, I do hear something when the key is in the crank position.....not the engine turning over, a quieter sound.
That sound may have been your wallet gasping for air. I agree that you should look at the simple stuff first. Leaving the back hatch open in the rain should not kill the battery. My 04 will extinguish the interior lights if a door is left open too long. The wet weather could have impacted your grounds though, and the ability of the battery to pass sufficient voltage through the starter, despite the rest of the car's electrics seemingly being ok. Unfortunately if you don't want to go back to the mechanic, you will need to enlist the help of a mechanically inclined individual to help you with further testing. Using the keyboard probably won't be enough. You haven't posted your location but perhaps there's an upstanding forum member in your area who'd be willing to give you a hand. After the online help, that's the next best thing about these forums. The next recommendation I'd give you is to get Triple AAA, at least then you get a free lift to the mechanic should you need to go. You shouldn't feel embarrassed about calling him back, after all this is a Rover. As I'm finding out, unless you have unlimited funds, you'd either better be a mechanic or be related to one to successfully campaign one of these trucks as reliable form of transportation.
Does the vehicle crank but not start, or no crank no start? Since you mention alarm system, I assume it does not crank or start...Without having vehicle in front of us its pretty difficult to diagnose car problems over the internet...
Either way I would get it back to mechanic and tell him whats up....
