04 tranny onto 01 chassis and motor?
Yea that cause he knows your going to have to make adjustments to make his stuff work in your 01. Not really worth the headache. 90,000 doesnt really matter call some tranny shop they will all tell you they never had a rover come in to the shop because of a transmission problem. Trans in these trucks don't just fail, however they were not designed to have the **** beat out of them by the drive shaft.
The transmission is the same. Its the case that is different. I've done the comparison before. The transmission is the same old ZF 4HP24 that its always been. And yes, the shafts themselves are different lengths for 2003 and 2004. If I remember correctly the front shaft is shorter and the rear one is a little longer.
