100 proof gasoline
Leaded high octane (also known as AVGAS, or Aviation Gasoline) will ruin your catalytic converters in short order, and might (but likely won't) cause injector problems.
Unleaded high octane will combust slower, resulting in slightly higher HC's in the exhaust stream, and if the stock tuned ECU tries to compensate you may end up with a power reduction. The only exception to this is if your ECU is specifically tuned to use a high octane fuel, then yes, you can expect an increase in power over a standard octane.
What won't happen, however, is:
- Frying of the valves and seals. They'll be just fine.
- Powahhh! There will be no increase (unless tuned for high octane).
Ethanol has less power per gallon than gasoline BUT it produces little to no emissions, so mixing it with gasoline reduces the pollutants from burning gasoline.
Take out the ethanol and you will increase MPG and power, you will not notice a power increase but if you were to do a dyno run, it would show on the computer.
These trucks are tuned to run 91 octane or higher, if you can get 89 non-ethanol you will be better off running that vs a 93 octane E-10 (10% ethanol)mix.
E-85 (85% ethanol)is 105 octane.
You can run 110 octane in a normal engine with no problems, will NOT hurt the engine in any way shape or form.
Anything over 110 octane will melt your pistons and valves, wont happen over night, but it will happen.
What? No... just no.
