yea...was reading about MAFs tonight. Looks to me like Cardone is an aftermarket and most people are insisting on a Bosch replacement. I found a Bosch for $100 on Amazon, but they are usually near $200 whereas the aftermarket OEM ones (Cardone, etc... are 100-140. The one I got was $120 but I remember it wasn't in a Bosch box (yellow with bosch and/or land rover emblems on it). May try the Bosch MAF and see if I can return the one I purchased at O' Reilly.
Originally Posted by lrsmith62
(Post 475844)
Did you you ever get a chance to try smoke testing with the MAF still on the intake tube? |
yes....same results. Have a Bosch unit on the way. Hoping O'reilly's will take the other back. I'm a good customer there, so I think they will. Also ordered a new gasket for the throttle body where I thought I might have seen a touch of smoke. Will keep you updated as I try both these fixes.
UPDATE.....well, switched out the MAF for a Bosch. No codes so far. I'm assuming the aftermarket MAF was the issue. Will update again if this changes but will call this case closed otherwise. Thanks for the help!
