120000 mile tune up
Hi all this is my first time posting on this site. Anyway, I have a 1999 discovery series two with 121,000 miles on it. It is time to get the 120,000 mile tune up on the car, however I was wondering if the $900 price tag is worth it. I would like to service the truck myself, as I do the oil changes and small things like that, but I am a bit skeptical about doing a tune up. Should I take it to the shop or should I attempt to do the maintancence myself (I dont even know if I need to have a diagnostic computer to do it anyway). I guess what I am asking is can I do the tune up with very limited tools, and if so, what things should be done. Thanks in advance.
RE: 120000 mile tune up
Here is you list of stuff to do. It can all be done in the drive way and I'll be glad to walk you thru it.
This is the parts list for a 60,000 mile service the way I do it. 1 Oil filter , K&N 3001 1 Air filter 6 Qts of engine oil 12 Qts of ATF 7 Qts of 80/90W gear oil 2 Qts of Brake fluid 2 Qts of synthetic Power steering fluid 2 Gallons of OAT, orange coolant 1 Bottle of Lucas Power Steering additive 1 Bottle of Lucas Transmission additive 1 Can of Spray Carb. Spray 1 Can Of Brake cleaner 8 Spark Plugs, I use Bosch Platium Plus 4's 1 Set of Magnacor 8mm plug wires 1 Serpentine belt if not yet replaced 2 Bottles of SeaFoam 60,000 Mile Service Bleed the brakes Flush and change the power steering fluid adding one bottle of additive Service the tranny adding one bottle of additive Flush the coolant system Do an engine flush before changing the oil Do an induction cleaning Clean the throttle body Add fuel additive to full gas tank Change both of the diffs fluid Change the t/case oil Replace the plugs and wires Replace the air filter Lube all the drive shaft grease fitting including the 2 slip shafts Do full inspection of brakes, hoses, bushings etc. Because of your mileage, you will also need to replace your 4 02 sensors. |
