2000 Disco II Running Hot & Backfiring in Intake
I have a 2000 Land Rover Discovery II (with Secondary Air) that about 6 months (and 6000 miles) ago after having a local shop do the head and valve jobs on both heads I replaced the head gaskets with Atlantic British Composite set. I used new head bolts and torqued to spec. I replaced valve cover gaskets and other gaskets that came in the kit from Atlantic British. At that time I put in new lifters, replaced the spark plugs and spark plug wires as well. The Disco has about 106,000 on it now.
Recently it started running hot. I have not let it get to the red on the gauge. I just replaced the radiator, water pump and thermostat. It will idle fine and the temp gauge will remain steady at dead center until about 20 minutes has passed. Then it starts creeping up and coolant will start to leak out of the bleeder screw on the top radiator hose. There are no other leaks and both fans appear to be operating fine. Also, it idles fine... however, when I accelerate I get backfiring through the intake. I removed and cleaned the MAF Sensor using CRC MAF Cleaner as per instructions. Still no improvement. I went to Advance Auto and they told me my fault codes are: P0305 P0733 P0734 P1590 Just got a new job and I need to get it running. |
You have a misfire on cylinder 5
1590 is your 3 amigos |
Originally Posted by lipadj46
(Post 151266)
1590 is your 3 amigos Thank you. What should I do? |
Well what kind of wires did you go with?
You can try to switch wire 5 with wire 6 and see if the misfire moves. You are not supposed to clean these MAFs btw, it ruins them in short order. |
What grade of gas are you using?
Have you flushed your radiator? |
Originally Posted by Spike555
(Post 151322)
Have you flushed your radiator? I always use Premium gas. Where can I get detailed instructions (with pictures) on how to flush the coolant system? |
Go to the "write up" section.
It's not hard, no pics needed. Just remove the lower radiator hose, reattach, fill with water, turn on heater run engine for 15 min, cool for 15, drain. Refill and repeat until the water comes out clean. Then refill with any aluminum safe coolant. Do NOT use DexCool. http://sancarlosradiator.com/dex-cool.htm |
(Post 151336)
It's not hard, no pics needed. Just remove the lower radiator hose, reattach, fill with water, turn on heater run engine for 15 min, cool for 15, drain. Refill and repeat until the water comes out clean. Then refill with any aluminum safe coolant. Do NOT use DexCool. http://sancarlosradiator.com/dex-cool.htm Thanks |
(Post 151336)
It's not hard, no pics needed. Just remove the lower radiator hose, reattach, fill with water, turn on heater run engine for 15 min, cool for 15, drain. Refill and repeat until the water comes out clean. Then refill with any aluminum safe coolant. Do NOT use DexCool. http://sancarlosradiator.com/dex-cool.htm Probably a dumb question... where is the "write up" section? |
The only stupid question is the one not asked.
The write up section is on the top of the main page. There is also a new member section that is highly recommended that you read. |
